1 - 14 of 14 Posts
I've been practicing this technique however, I've been having some difficulty with doing it the conventional way of heel on gas, toe on brake. I'm 5"11 with a size 10.5 shoe. No matter how far I put the seat back, my knee gets caught up by the steering wheel or something. If i put the seat back far enough, i have to really stretch to reach the steering wheel. Then there's that problem with my feet. I don't have big feet, so i suppose it's my coordination that makes it so difficult to do this operation. So i decided to try heel on brake, and toe on gas. It seems to work better and i guess with more practice, i'll become more fluid. Are there many people who drive toe/heel, instead of heel/toe? And for the more experienced drivers, are there any tips that may be useful for me? Thanks.
i m not as tall, only 5'6 or 7... but sometimes when i do heel toe, my knees hit the same spot also.
I heel-and-toe occasionally, but I don't have problems with my knee hitting anything. I'll get around to taking pics of how I position myself one of these days...
I have the same problem. I am 5'10" and 10.5 shoe size too. I think the gas pedal of is300 is just too small unlike the bimmers'. I haven't tried toe heel, thanks for the idea, I will try it and see if it's more comfortable.
Whenever I heel and toe (not in my car unfortunately :(), I would use the sides of my foot instead of actually using my heel and toe. Just get a pair of wide tennis shoes and that should do the trick.
that doesnt really work w/ the IS...
cuz the brake pedal is too high...
Ok, I woulnd't know since I've never driven a manual IS. It worked on my friend's old GT and his WS6, and it also worked on and old Turbo2 RX7.
Mr. Negative
That's what I've done when I drive a MT IS, with my foot a little at an angle like this " / "
so u mean you heel the brake and toe the gas ?
the opposite ?
Mr. Negative
the opposite ?
Not exactly. It's actually more like the ball of my foot is on the brake and the right side of my foot is on the gas. Since the pedals are so close.
In general, just do what feels most comfortable to you. I was taught that the most important thing is having the ball of your foot on the brake for safety/control. For me what works best (with the IS) is to place the ball of my foot under my big toe on the brake with your foot rotated in this direction / . With my 11.5 shoe that doesn't require much rotation of the foot, I can just roll my ankle slightly and blip the throttle with the outside of my foot. If you're hitting your knee on the steering column, you can try rotating your foot a little less. Hope that helps. Good luck.
you need to have you ball on the brake and blip the gas with the heel or side of you foot.
The lexus pedals suck for this, part it the position from the floor the other is the distance of the pedals.
You can fix the distance of the pedals buy pushing on them, do not push to hard they might break. They do move around if you push on them. I have moved the brace closer to the gas by about 1/2' to 1'
It's easy on my Bimmer, but can't do it on the Lexus or most other cars (size 12 foot) - I wouldn't recommend toe&heel, cause when braking is critical you need to feel what the brakes are doing through your foot, hard to feel anything or modulate anything with your heel.
Get a pedal kit for the IS - that's what I would do if I got one.
Using heel and toe isn't much of a problem for me (5'5, size 9.5 shoe) in the MT IS300. Every car feels different using the H&T, some feel better than others.
I agree that if you need to use this method, you could try pedal covers like how it was mentioned earlier. I've had a lot of practice in my GTI, 240SX and AE86. The IS300 does feel a bit closer pedal wise but it's not impossible to master. (unless you have Shaq's feet)
1 - 14 of 14 Posts
