Do power acoustik make good amps? If not, who makes good 3,000 watts amps or amps that are compatible with two AudioBahn 15" Linear Compression Subwoofers (3,000 watts rms each). Thanks.
Uh, no.
JBL makes, I believe it to be, a 6K WAtt amp? It's made with the help of Crown.
But, there is no sense in getting any amp at a TRUE 3KW or more, unless you want to spend MAJOR MOOLA in upgrading your power supply.
Useless
HiFonics Colossus is 2800 watts RMS. This is true raw power from a Class A/B amp, none of this Class D crap.
