1 - 10 of 10 Posts
hey, i heard from a friend that the pyrometer is alot to install like $500 and is not needed with a turbo setup, he mentioned a/f and boost, no fuel pressure, maybe oil...also what is the best price anyone has seen on autometer guages the cobalt series....
You friend is a RICER.
IF... his talking about those red/blue light A/F gauges. They wont do jack s**t unless its a wideband 5 wire o2 sensor you got with a voltage conversion. Pyrometer (EGT) is important, but only once you tune your car because each car will run different temps so it will be accurate to YOUR car onced tuned. My personal order by importace:
Boost
Wideband A/F
Fuel Pressure A MUST of you changed your fuel system.
EGT
Oil PRessure
cariza said:
You friend is a RICER ... and a shit talking jackass, tell him not to speak to you
Boost
Wideband A/F
EGT
Oil PRessure
well... EGT.. pyrometer... both check temps, except you dont use EGT to check out tire temps, CPU temps or whatnot. :crazy:
Nygmatic
pyro = fire = heat
meter = something that measures
hence... pyrometer is something that measures heat (temp) whether its for tires, water, or exhaust temps.
1 - 10 of 10 Posts
