1 - 12 of 12 Posts
Hello everyone,
New to this community here. I am looking to purchase a 2001 IS as a DD for around $4k. Just wanted to know if this was a good deal, and what I should be looking out for with something that high of mileage. It's mainly going to be used just to get to and from work, about 7 miles each way, all local. In Vegas, so nlo snow. Thanks in advance for your help!
I think these are great daily drivers despite their bad gas mileage. 4k for 180k miles may be a little steep, though I may have gotten lucky when I got mine for 2500 with 138k miles. Definitely check for timing belt replacements and see if that's something you'll have to worry about. Also it's pretty common for these cars to have bad sensors but that shouldn't be a serious deciding factor, just something you could use to help bring the price down. One of my sensors has been out since I got the car around a year ago but I don't really mind driving without abs, traction control, etc you just have to be extra careful, especially in the rain. Lastly, check for rust. My 01 spent almost the entirety of its life down south but still had a little bit of rust.
These are just a couple of things I'd look out for, obviously there's more general stuff to be cautious of but these were the main things that I was concerned about when I got mine. I personally think IS300's are exceptional cars for the money, they're very reliable especially left stock and would make for a fun commuter that shouldn't give you too many problems. Just be sure to bring a mechanic to help check it out if you don't know what to look for.
Do you have any plans for modifying it, or do you want to keep stock? One thing I regret doing was not researching the cost of modifying is300's, they aren't exactly cheap.
Mr. Roo
That definitely seems like a steep price for an '01, especially in that area. And it will have issues here and there, it's just a matter of what when. You might get lucky, or not. Buying a high-mileage car is definitely a risk/gamble. It's just up to you and what you want and what else is available locally.
What would you guys say is a fair price for an '01 with 180k miles?
At 150k miles - timing belt, water pump, thermostat, and vvt solenoid gasket replaced, as well as full tune up
Stock Shocks, but fronts were just replaced recently, same with disc brakes in the front
That price isn't horrible if it's been maintained and in good shape.
One thing to look at is the lower ball joints in the front tend to go with high miles (search the forum and the IS Facebook page and you'll see). Same with the No. 2 lower controls arms in the front.
what else should be looked at besides (timing belt, water pump, thermostat, and vvt solenoid gasket replaced) for the engine wise?
The covers the big ones. The valve cover gasket, cam and crank seals are prone to leaking, but the same is true with any older car and they should probably be changed when the timing belt is replaced anyway.
Other than that, I'd be most concerned about the front lower ball joints. They're prone to failing unexpectedly and if they've never been replaced, or have been replaced with cheap aftermarket parts, replace them immediately with OEM and get the car aligned promptly.
Without maintenance records, assume everything will need replacing soon. Suspension, plugs, tb, seals. Build that into the price. No records = $2500, with complete records and up to date maintenance $4500 isnt unreasonable if its rust free and no accidents. Bring a 10mm wrench and hex wrench and remove the TB cover. Look for belt wear, oil leaking from cams, crank anf VVTi cam. 180,000 is when the vvti can seal usually fails.
its a non-starter for me if its been in an accident. Regardless of price.
The vvti cam seal can be replaced for $10 or less. took me 20 min or so. Ball joints are cheap, get Moog replacements, equal to OEM IMHO. Valve cover gaskets are cheap. $40 for both and takes an extra 45 min when you change your spark plugs. The one thing on a high mileage IS300 that WILL need to be replaced along with the lower ball joints are the #2 lower control arms (bushings wear out). They can cause bad inner tire wear if not replaced.
The only real question is if the person took care of it well. 130K miles on a poorly maintained car can be worse than 180K on a well maintained car.
Good Luck!
1 - 12 of 12 Posts
