Does anyone know the maximum rpms you should have when the engine is cold? I know that hard driving with a cold engine is bad, but exactly what is considered "hard driving" when the engine is cold?
i try to warm up for a minute, then keep it under ~3000 rpm until normal operating temp
one reason to go easy on it..
You have a aluminum head and a Iron block, they both expand at diffent rates as they heat up and get to operationg temp. You generaly are more likly to blow a head gasget. If you run them hard before they warm up.
juan
