1 - 20 of 21 Posts
ProEFI offers both the Pro48 and the Pro128 plug and play units for the Lexus IS300. The listings with the ** are only available with the Pro128 ECU.
Fuel
Ignition timing
I-Boost Control (5 stages of boost curves that can be selected to be targeted against Vehicle Speed, Time, or Flex Fuel input)
Flex Fuel (ability to run any mixture of E85 with the ECU making on the fly adjustments to boost, spark, and fueling based on Ethanol content).
Antilag Boost control - 5 different target boost levels
TwoStep Launch Control - 5 different target RPM's
Hi/Low Octane switch - Allows the user to easily change the calibration to run pump gas and race gas settings
Nitrous Control - up to 4 stages
Control multiple fuel pumps in stages for easier fuel pressure control at lower flow demand
Automatic Transmission control with converter slip calculations to help with converter selection and seemless converter lock up engagement.**
Manual transmission Gear position indicators and clutch slip calculations**
2 channel Knock control with knock windows and true knock frequency filtering**
Variable CAM control
Electronic Throttle Control
Fuel Pressure Feedback and fault control to monitor proper fuel delivery to prevent engine damage due to fuel system failure
Oil Pressure monitoring to alert when low oil pressure conditions occur
Radiator Pressure monitoring to warn for excessive coolant pressure in case of a weak head to cylinder block seal, or cracked cylinder.
Traction Control**
Closed Loop O2 Feedback with Internal Wideband O2 sensors**
Multiple Fault Management strategies to save the engine and alert the driver incase of sensor failure or tuning errors
CAN Display connectivity - 52mm Can Gauge, and 4.5 x 4.5" CAN display.
Meth injection - ability to control methanol injection and tune appropriately for it
PM OR POST UP FOR MY.IS PRICING!!!
Regards,
Robert
how does this work, just plug it in and go? what if i have a SRT intake with ECU? manual transmission
Definitely NOT plug it in and go. Must be tuned....
I've been drooling over this EMS the day it's been released. It's the only standalone I'd consider.
Send me some details please.
Looking for a ProEFI 48 unit, could you give me a price for plug and plug harness, flying lead, and plug n pin kit.
I cant find a Haltech tuner and working with a tight budget so I am cheaping out.
What's the lead time on the unit?
Can I get a price for both the 48 and 128 pnp shipped to 16148 please? Thanks.
1 - 20 of 21 Posts
