1 - 8 of 8 Posts
what is the rate on these coils? do the custom valving option only go up to 16k without the swift upgrade? What material are the top and bottom mounts?
It also may be a good idea to state that no camber plates are included. It looks like you're using a stock image for these coils.
Vendor
Discussion Starter #3 (Edited)
Top hats are included. The IS300 doesn't use a macpherson strut, so it would not benefit from camber plates.
The Prime coils are their off the shelf solution that are stocked. It is a different pricepoint and different product than their bespoke suspension such as the FA500 line. And as these are being blown out, there is no custom valving offered on these at this time. Spring rates are 10k/8k.
If you are interested in a 16k setup, give me a call and we can get you a great price on a set of FA500s. Thanks.
Vendor
I'm sorry?
You asked sring rate. They are 10/8. You asked about custom valving. There are no custom valving options for these at the moment. If you want custom valved coilovers or higher spring rates, we should be discussing the FA500.
You are correct that they don't include camber plates, as they are not applicable for the IS300. They do however include top hats with sphericals.
1 - 8 of 8 Posts
