1 - 8 of 8 Posts
Any tips...should I remove the serpintine belt first? I am replacing all my accessory pulleys and swapping them with the ralco set...not using the crank pulley. If I turn the nut all the pulleys spin no real place to hold it still...any help will get rep! Prolly going to remove the ac unit soon aswell going to do a custom dry sump system.
post up pics and maybe a DIY!!!!! i remember i just had someone hold the pulley with the belt off and went at it with a breaker bar....
I will give it a good try tomorrow...I think we can hold it still with rope wrapped thru the hole and me holding it...I guess I should just remove the serpintine first.
Yea simply stick a screw drive in between the opening of the pulley, that should stop it from turning.
That is how I did it.
1 - 8 of 8 Posts
