21 - 28 of 28 Posts
Okay, Have you checked the wires going to the doors for power? If there is no power. You will need to trace them back to find the break.
That’ll be my next step unfortunately this weekend :/ if they’re not getting power at the window, where should I check next?
Sent from my iPhone using Tapatalk
I guess what I’m confused about is what caused the issue, one day they were working fine, then next they stopped after I put my battery in my trunk. I just rehooked up my battery in the stock location and it still didn’t work.
What issue would cause all three to go bad but the drivers side works?
Also which is the right relay to replace? I want to make sure I didn’t mess that up
I fixed the front but haven't messed with the rear. Go through and make sure you've replaced ALL of your headlight fuses. There are some that aren't super noticeable
i made sure to replace all of the fuses. The rears still dont work so im figuring that out next haha
21 - 28 of 28 Posts
