Ok, I replaced the master switch for the windows and now I have 2 windows working, yahoo!!!!. I've ordered a second "used" master switch to see if that will fix it.
I know you are right of course but if I told you how much I've spent on this car you would understand.Damn man you have had trouble with this for almost a year.
Maybe it is time to take it to a dealer.
???? Dome fuse is interior lighting...seperate fuse. That does not affect the OP's issue.also check your dome fuse.
Thanks for the above post. You fixed my problem. I just replaced the battery and noticed the windows were not working. I removed the ground cable and reinstalled it and now all windows are working fine. Thanks again.I had a similar problem one time and I just took off and reinstalled the ground cable to the battery. the windows and raido were acting up and then worked fine. Not sure what the cause was but it did fix it.
