1 - 16 of 16 Posts
Power Enterprise CAMCON VVTi/VVTL-i Cam Timing & Air/Fuel Controller!!MVP Motorpsorts
CAMCON
The CAMCON-T allows you to take unrestricted control of your VVT-i valve timing into your own hands. Along with this, the ability to control your A/F will allow you to more efficiently and precisely tune your vehicle giving you a higher level of performance and fuel economy.
TOYOTA VVT-i & VVTL-i
The CAMCON-T controls the VVT-I timing +/- 20 degree in 15 different points of 500rpm increments within 2000rpm to 9000rpm Range. A/F is controlled -10% to +20% in 17 different points of 500 rpm increments within the range of 1000rpm to 9000rpm. Easy Installation
Works on Toyota VVT-i / VVTL-I Engines
$440 MSRP
PM OR POST UP FOR SPECIAL PRICING!!! GUARANTEED TO NOT BE DISAPPOINTED!!!!
Regards,
Robert
Thanks for the call bro! Mines on order...I'll let people know how this is when I get it :)
You have to cut some wires or bypass a few on your ECU, I think you need:
- MAP-Signal (in & out)
- rpm-Signal (in & out)
- VVTI- Signal (in & out)
- 12Volt
- Ground
- maybe TPS
Than you route all the wires inside your cabin and mount the controller somewhere.
If you'r planning to get a Greddy ultimate you dont need a CamCon cuz you can control your VVTi with a Greddy ultimate too.
The last but not least VVTi can only change the inlet CAM on the 2JZ and the 1G-FE I guess and it can only adjust uot to 5° so Power gains are in the drop-in-air-filter region.
I will run my CamCon only to adjust the VVTi and do timing and fueling with a MAPECU2 so the CamCON wont be connected to the MAP Signal. If both thingys wont sit here I would definitely go the Greddy ultmiate route.
With tuning what gains are we talking about? Or is it more for the curve? Obviously being able to control vvti will allow a better curve but for power?
Discussion Starter #9
Gains will be totally dependent on all your mods sir. You will see an increase on power but how much will depend on a number of factors.
Regards,
Robert
Is there any more info on this unit? I was reading the article in the magazine posted above and they gained 14hp on a stock celica. So let's say we have I/H/E with BC cams and cam gear what gains should we see... approximately?
Hey Robert, cant you tune the VVTI on a standalone? Or am I missing something ??
Like an AEM V2 perhaps?
Discussion Starter #13
Hello Yogujuhere,
Just called AEM and unfortunately they are closed for the day. I will confirm 1st thing Monday for you.
Regards,
Robert
Question ?
1. This is Suitable for Toyota Engines:
3SGE Dual vvti - Altezza RS200
I know there more model engines as like:
- 1JZ-GTE, 2JZ-GTE, 2JZ-GE
- 1ZZ-FE, 2ZZ-GE
- 1SZ-FE, 2NZ-FE, 1NZ-FE, 2SZ-FE
- 3S-GE
- 1G-FE
Discussion Starter #16
I was just informed the CAMCOM is discontinued due to some revisions being made. The new Version will be ready to ship in August.
Regards,
Robert
1 - 16 of 16 Posts
