1 - 20 of 46 Posts
Poll of MODs and Settings
Go Fast
3" custom mandrel bent exhaust (68k)
3" Magnaflow muffler (68k)
Token Solutions PNP O2 deletes (68k)
Brian Crower 264 cams (100k)
Titan Cam Gear -4 (100k)
Ralco RZ accessory pulleys (111k)
3.5" Apexi Active tail silencer (112k)
PnP 80MM Throttle body from LX470 (112K) (Retains factory cruise control)
Wabro 255 (114k)
Fidenza 13lb Flywheel (118k)
Stage 3 sprung Clutch master Clutch kit (118k)
Go Faster
Injectors 700cc (130ishk)
Turbo gt35 (130ishk)
3" downpipe
40mm Waste Gate w/9lb spring (130ishk)
12x30x3 Intercooler (130ishk)
3" IC piping (130ishk)
Synapse BOV (130ishk)
Stealth motorized Gauge display that pops up in the center of the dash and automatically closes when the car is shut off.
Boost Gauge (Sunpro Black)
Innovative Wideband O2 and A/F Gauge
Stop, Drop and Roll
Wabro 255 (114k)
Hotchkis Sways front and rear (118k)
Tien S Tech Springs
Bilstien HD Shocks and Struts (118k)
Drilled Rotors and new pads all around (115k)
SS Brake lines (75k)
Next set of mods:
EMU (Waiting to be installed)
dyno tune (after the above is installed)
Adjustable control Arms, FIG style (Waiting to be installed)
Maintenance items:
Plugs (Done) 111k
Plug Wires (done) 115k
Timing belt (done) 100k
Front Main Oil pump Seal (Done)118k
Timing belt (done again due to Oil from front seal leaking all over the timing belt from the 100k service) 118k
Water pump (done) 100k
Camshaft seals (done) 100k
Valve cover seals (done) 100k
Thermostat (done) 100k
A/C Evaporator Core (done) 105k
A/C Drier (done) 105k
A/C Expansion Valve (done) 105k
Coil Pack wiring harness plug replacements, part number 90980-11246 (Done) 105k
Rear Main Seal (118k)
Oil Pump (118k)
Front Main seal (118k)
I.C.E.
Infiniti 2-way 6.5” in the front doors
Infiniti 3-way 6x9” on the rear deck
SoundStream 2500 watt 4-channel amp (pushes the Infiniti speakers)
Double Din Dash kit
Pioneer ahv-p4300DVD 7” touch screen (waiting to be installed)
potentially:
BC Valve springs
GTE internals (to be ordered)
Current pic, Powered by methane no CAT...
This thread is kinda pointless. Just look at peoples sigs
2002 Auto IS300
Mods:
Custom Air intake (modified AEM intake shortened 1.5" going to sheet aluminum air box with cold air fed to the air box from behind the passenger side fog light hole)
Mazzuri Super Gen 1 headers port matched
Tanabe super medalion racing cat back
Fidanza Cam Gear -4deg
XVT Valves/3 angle valve job
Lightly ported head
Port matched, lightly Ported intake manifold with butterfly removed
20 over JE pistons (8.5/1)
Eagle Rods
TT head gasket, ARP studs
Meziere Electric Water Pump
Mishimoto Radiator
Fuel Pressure Pulsation Damper Removed, -6an fuel line
Not yet installed:
Unichip (might not end up using, but got a good deal on it)
Holset HX35 with Map Width Enhancement
2002 Auto IS300
Mods:
Custom Air intake (modified AEM intake shortened 1.5" going to sheet aluminum air box with cold air fed to the air box from behind the passenger side fog light hole)...
...Fuel Pressure Pulsation Damper Removed, -6an fuel line...
Very interesting have any pics of this setup... is the aluminum box completely enclosed?
Thanks
Yeah but having one place where people chooses to respond is better than drugding through every thread looking for sigantures and not everyone has a signature.
Thank for joining the pole. (pun intended) ;)
2001.5 IS200
Rare APC Green Underbody Neons
Rare APC Green Underdash Neons
Ebay front strut bar wrapped with carbon fiber tape
Clothes Dryer hose mated to Spectre Filter
Crush bent exhaust with gutted cat going into a 94 MR2 Turbo Muffler
Silver Mirrored Tint
AEM Exhaust Cam -2
AEM Pulley Set
Ebay header painted with chameleon paint to give it the titanium look
obx 264 cams
2001.5 IS200
AEM Exhaust Cam -2
AEM Pulley Set
obx 264 cams
No shit I have that setup too, but i have blue APC neons
you can kind of see it here:
It's the Weapon R cold air box, modified to fit correctly (cause Weapon R's products suck), then sealed with foam to the surrounding edges. What I did for the cold air part is got one of these:
Spectre Aluminum Air Duct Mounting Plate
Drilled a hole like you would for IC piping and mounted it with some of that foam tape in between it and the chassis, then connected that to a bell mouth I mounted in the fog light hole.
Discussion Starter · #11 · (Edited)
2001.5 IS200
AEM Exhaust Cam -2
AEM Pulley Set
obx 264 cams
Sounds Ideal, this is the example Mods should set. Though I am really disapointed that you don't have the ebay halo head lights, the stick on hood scoop and the crane kick SUPER wing. What I am realy curious about is how you got the 94 MR2 tubo muffler to fit. Let me guess you no longer have a spare tire.
Thank you for your support,
Very intuitive thanks for posting.
Zeitronix ZR-1 Wideband
Ebay Turbo Manifold
60-1 .68AR T4 Turbo
Ebay 75mm Throttlebody
Precision Turbos 46mm Wastegate
Tial Blowoff Valve
Turbonetics Boost Controller
RC Engineering 550cc Injectors
Devils Own Methanol Kit
GTE Internals
GTE Headgasket
Aeromotive FPR
ACL Bearings
Custom Mandrel 3" Exhaust with Magnaflow Muffler
Battery Relocation Kit
Oil Filter Sandwich Plate
Titan Motorsports Cam Gear
AEM Standalone
Brian Crower Stage 2 Cams
Custom GTE Style Intake Manifold
Aristo VVTI Valve Covers
Aristo VVTI Spark Plug Cover
HKS DLI II
Custom Fuel Return System
Unorthodox Racing Pulleys
Golden Eagle Vacuum Manifold
Mishimoto Black Intercooler
Transmission Cooler
Oil Cooler
BC Valves, Springs, and Retainers
Port and Polished Head
Oil Filter Relocation Kit
Happy? LOL
Discussion Starter · #14 ·
Happy? LOL
NO ! :cool:
I used a 18" x 3" resonator and vortex 3" muffler. It actually sounds great under WOT but the daily driving 2500 to 3000 rpms resonance is killing me. I bought a Magnaflow 12259 to replace the vortex hoping to quiet it down a little. Think it will do the trick?
2004 IS3 E-SHIFT
BC Stage 2
Titan cam gear - 0
Xerd headers
Xerd race pipe
DTM B pipe
Stillen axle back
MRF custom cold air intake
MRF black box
SAFC2
AEM A/F gauge
Tein CS
Volk TE-37 19X8.5 (((polished)))
H&R/Ichiba
Or you can just look below at my sig ;)
Super Moderator
I disagree with you.......Sigs are over rated !!!
04 TCM
OlD set up 2009
Engine-----------------------
LMS CAI (KN filter)
HP Header
Toyomoto Y pipe
Greddy Evo II
Current setup ---------------2010
Engine
Head
BC Valves
BC Valve Springs
BC Titanium Retainers
BC Stage II Cams (264)
ARP Head Studs
Greddy Cam Gear
Gates Timing Belt
UR Racing Pulleys
JoeZ Style Intake Tube
KN Filter
Rad Panel
AlphaWerks Header (wrapped)
AlphaWerks Y-Pipe
HKS Axle Back
TS PNP O2 Sim
------Alot more to come
Suspension------------------
TRD Struts (from Japan)
Tein S-Tech springs
Hotchis Sways
rear strut bar
-To Do list-??
.......Alot of stuff and no my sig wont give those up coming mods away......
Car is currently locked away for winter...
2004 TCM 5MT
Turboeast stage 1 kit
-Current exhaust 3" turbo back until right before axle where it drops to 2.25 then to a 2.5 HKS muffler :-/ (3" axle back waiting in basement)
Tokico shocks and springs
ACT 6-puc clutch
Dunlop Direzza Sport Z1 Star Spec Tires
-Currently in Garage getting beauty sleep
- Many parts awaiting in basement. Waiting for Bezik777 to let me loose :p or summer whichever comes first.
Super Moderator
2004 TCM 5MT
ACT 6-puc clutch
:investiga lol
i guess its my turn ugh...so much to type
Supra TT front brakes
Brembo blank rotors
Hawk HPS pads
SS brake lines
Stance GR+ Coilovers
Toyo Moto Header
Megan y-pipe
Apexi cat back
BC stage 2 cams
BC valve springs/retainers
Joe-Z Style intake
Unorthodox Cam gear
TRD Red sway bars
Up Coming mods:
TurboEast Stage 3 S/C setup
P1SC-2 Procharger with 13psi pulley
Intercooled S/C setup with a BOV
Percision 550cc injectors
Piggytails from boostlogic
Walbro 255 fuel pump
Emanage Ultimate with PnP harness
VB upgrade
2mm head gasket
Trans cooler
Stri Racing Boost gauge
AEM 6 in 1 Uego wideband AF sensor and gauge
WRX fiberglass tripple gauge pod
BC Stage 3 cams (maybe)
Gates Timing belt
I want spring :)
Super Moderator
leonard + Paul..must of let his ninja mode at home.....now how are the midwest boys going to be able to hittem up stealth mode when they know what we are rolling with ...Gosh
1 - 20 of 46 Posts
