Long story short was driving car shut off towed home EFI fuse under hood blowed put new one in fired up with (R) reverse indicator on in gauge cluster on with reverse lights on put in drive reverse lights stay on and won't shift out of first put new neutral safety switch car doesn't crack at all reverse indicator still on.. Looked at codes shows it throwing same code PO705 Transmission Range Sensor circuit fault :2004 Sportcross
Do not know what year. Because of where you posted and not saying. If you got enough of a load to blow a fuse. You may have a short. The two circuits are not on the same circuits.
It's a 2004 I been checking for shorts but haven't succeeded yet
Did you replace the range selector on the transmission? Or check the wires going to it to make sure it was connected good.
