I have a plp short shifter gen 2.....Im recently having problems shifting into 4th and 5th gear. It almost feels like you are going 5-10 mph and you are trying to shift back to 1st gear...as if it's gonna grind or something. Today..I took off the plp shifter and notice it needs some lube or oil. What should I do..right now, when I move the shifter to the left, it gets stuck (like how you suppose to shift to 1st and 2nd) but Im still in neutral. Does this have anything to do with tranny oil?
And one more thing....on the very bottom of the short shifter, where the metal ball is...is there suppose to be that little plastic piece moving around cuz I think that white plastic piece is stuck in the hole where you stick the shifter in.
