PLP Front Strut Bar
329 Shipped brand new.
The new alloy, Competition-lightweight or "CL", is CNC machined from solid aircraft grade alloy, heat treated to T-6 specifications for added strength. The CL breaks new ground in the alloy strut field by utilizing our exclusive "Direct Block Pivotless Design." Extremely robust and immovable, this design features an extended cross bar that attaches directly to the laser cut tower ring block without the need for additional fittings. There are no "hollow tubes" or "pressed components" in the construction of the CL. In addition, we continue with our massive, proven, 1.5 inch wide and .5 inch thick, machined alloy cross bar with weight saving, decorative, drilled holes. The PLP "CL" front strut bar clears the engine cover and hood perfectly.
-Eddie
