I hooked up a PS2 to my stock headunit. The sound is absolutely horrible. I tried using an FM Modulator, then switched to an FM Transitter because I heard that would be cleaner sound. No luck there either. What kind of fm modulator or fm transmitter didja guys use. Do you guys have the same sound quality problem? Where did you ground to? Maybe that is my problem. Any input would be greatly appreciated.
