good Q........
Since the stock bumper is still there under the Area 51 Lip & the lip juts out in front of the bumper nicely, it works perfectly al lteh stock undertray mount points that the PLP panel was designed to work with are stil lthere so no problemo... now if you went with a complete aftermarket front bumper.... that might pose problems if it does not have those mounts like the stock bumper has i nthe same spot as i 'm suire it most likely would not...
PS...I actually made one slight mod to this pic..... i found that when the radiator spits out a bit of fluid.. .that pink coolant stuff poured right out the tube & onto the tray & left a nasty pinkishwhite residue after it dried looked crappy & i saw the same crap on the plastic one too.........
So i pulled the tray after i took this pic (this was taken when i 1st installed it), & added a length of hose to the radiator over flow tube, then I drilled a hole in the center of the PLP Panel RIGHT below the radiator tube, & fed the tube thru the hole while reinstalling the panel so the excess fluid now pops out right onto the ground & does not Pool there on the shield &dry up leaving the flaky crusty pink white residue that looks so shitty....
i'll take another pic & post it
edgy
edgy
