1 - 11 of 11 Posts
I'm planning a combined DIY maintenance job consisting of:
  • Spark plugs
  • Injectors cleaning including new o-rings
  • Throttle body cleaning
  • New PVC valve
  • MAF cleaning or even replacement
1. What else should I do on this occasion while having the intake removed?
2. What gaskets will need replacement during this job? Injector o-rings are obvious, but other?
3. Denso or Delphi MAF?
Good time to do the cam cover gaskets, won’t add much more to the cost. Get the gaskets, oring washers, and some Toyota FIPG. May as well clean the VVTi solenoid filter too.
Be prepared to replace air hoses that may have become brittled and would not fit in after being removed. Had to replace three of those in my last job
Also suggest getting new wire connectors for the coils. If yours are original or old the plastic connector will be super fragile and you'll probably break some while pulling the coils, etc. I found them on ebay - there are several sellers. If you are handy you'll easily figure out how to replace them - it was not difficult for me.
Thanks for your tips. Today I've started and removed the intake, fuel rail, injectors. Some new findings:
Is this diesel-like sound normal? If not, is it bottom end or do valves need adjustment?
134356
Do I have two PCV valves? The one on intake side (red) is threaded, the exhaust side (blue) isn't.
Ordered them. Replace even if the original one aren't leaking?
Noticed some hoses having brittle tips with tiny cracks, but none of them looks really bad.
Ordered them too.
Discussion Starter #7
Get a mechanics stethoscope at the auto parts store to narrow it down.
Will do it as soon as the engine is assembled back, but is there something to check now with intake being removed? Except for valve clearances which I'll check since I'm anyway proactively replacing the valve cover gaskets.
Not that I can think of. Like I said. It my be an exhaust leak.
Discussion Starter #9
Found a thread where a fellow forum member had same sound and it turned out to be the water pump. Will leave it here in case someone will later stumble on this thread.
Man if you’re doing the water pump you may as well do the timing belt, tb tensioner, tb pulley, cam seals and front main seal too. Quite a bit bigger job but comes due every 90kmiles/6 years.
Discussion Starter #11
No no, not planning to get so deep. Hope very much it's not the water pump, although there's a risk: it's still the original after 125k miles. Previous owner who changed the timing belt at Lexus at 60k didn't change the pump.
1 - 11 of 11 Posts
