Hey guys I'm gonna be installing my getrag 6 speed soon and I was wondering if I need to reuse the is300 pilot bearing or do I need to buy a new one? If I need to buy a new one, which one? Is300 or supra GTE pilot bearing?
Thanks guys
-Henson
Thanks guys
-Henson
get a new one if your clutch does not come with it, and get a supra tt pilot bearing. You will also need new flywheel/pressure plate bolts, washers and snap rings....call curt at elmhurst toyota or jeff watts at champion toyota.
Cool thanks. The pilot bearing is all I need. I have everything else. Thank you
maxxpsi said:
make sure you don't use a lightened flywheel.
I 2nd that
Discussion Starter #6 (Edited)
Yea I ended up getting the hpf feramic clutch w/ act pressure plate and oem supra tt flywheel. I knew the gearing would be way too fast with a lightened flywheel. I also got the titan motorsports clutch line.
