So for those of you with the JIC FLT-A2's, they come with an adjustable pillowball mounts for camber and caster correct? If that is true, then would you still need a set of adjustable camber arms to correct negative camber? If the range on the pillowball mounts is only so many degrees i can understand needing the camber arms.
