1 - 20 of 45 Posts
This dynp pull was done at 19psi.
Race gas dyno will be done shortly :p Pretty decent increase in power considering I was making a little over 400rwhp w stock cams. This dyno is with the hks 264 cams. On a preliminary dyno run with c16 the car made 501rwhp at 19 pounds with a little more timing.
Nice numbers, Aldo!
How many pounds to you anticipate running on race gas? 29 or 30psi still?
Keep 'em coming, your car is sick.
-Chris
I dunno, depends on how smoothly everything goes, my car is on the dyno with c16 as we speak :p Friggin loud man, thanks doub for the props.
excellent curve/numbers!!
looks like i still have the record for pump gas
that has to be his car
650rwhp would be too low for my car at that boost level
fairuza11 said:
ltuned&boosted said:
just saw 650rwtq a 29 psi :D Looks clean.
GTE sent you a Dyno of him at 650 rwtq at 29psi on pump gas?
yeah I was gonna say..#1 29psi on pump is possible but scary.. and #2 on your setup 650rwtq should be achieved at like 23psi not 29..
you got any numbers yet to share GTE??
all 3 of you are just scary with those numbers I will die for high 400's low 500's :crazy:
GTE can you answer this have you broken the 1,000 mark on any kind of gas? in the IS?
if you don't want to post thats fine PM me then :D
1 - 20 of 45 Posts
