Ok I will take a look. I looked in the FSM and Owners manual, both don't show how they come apart.
I am sure its very straightforward.
The plastic housing comes off on the long side (closest to the windshield) held by two little plastic tabs. Put a flathead screwdriver underneath the long side and gently pry, and it should drop right down.
FYI, if you want the original OEM light, you may have to order it directly from the dealership. Replacement bulbs from retail stores like NAPA, AutoZone, O'Rielly's, etc. are much dimmer, but are also a couple of bucks cheaper if you don't use that light often.
