Just noticed this existed about a week ago, emailed them and got them to send me the manual cause it's stupid cheap ($161.89) and I wanted more info on what it could do.
Summary:
Mod MAF or AFR 16x24 map
Upper and lower limits for map above
Side map for Temp, maybe TPS also?
Additional Injector Driver or Boost Control 16x24
1 Channel Ignition Advance/Retard via crank signal again 16x24
Not sure if the ignition will work for us, or screw things up since our ecu uses crank and cam signals.
Summary:
Better or worse than SAFC2..?
Better and cheaper, even without the timing control it still has a higher resolution then any of the Apexi AFC (Super, Neo, whatever)
I have heard of other Toyotas that use cam/crank still effectively retard timing via just the crank signal, so that may work.
MAF based piggies IMO are not that bad when doing moderate upgrades such as N/A or very moderate boost/injector changes.
