i am about to do the 5 speed swap, and pedals for the is are crazy expensive. we all know this. i was sitting in my buddies 7th gen celica, and to my surprise, i look down and it has the same pedals as the IS!!! has anyone explored the possibility that the celica pedals are in fact the same assembly as the is?
Discussion Starter · #2 ·
found this... this is a list of part numbers for the celica clutch pedal assembly...
ToyoDIY.com
copied from LO21's swap thread...
CLUTCH PEDAL & FLEXIBLE HOSE
Clutch Pedal Sub-Assy 31301-53050 $52.10
Spring (For clutch pedal) 90949-03119 $2.26
Cushion No. 1 90541-06036 $2.91
Bush (For clutch Pedal) 90386-13015 $4.38
Nut (For clutch pedal stopper) 94130-01001 $0.89
Bush (For clutch Pedal turnover) 90389-06055 $2.03
Compression Spring 90949-03111 $14.76
Clutch Pedal Pad 31321-53010 $26.12
Clutch Pedal Shaft 90101-10015 $1.08
Clutch Pedal Shaft Collar 90387-10003 $4.73
Clutch Pedal Spring Holder 31353-35010 $11.52
Pin (for Clutch master cylinder push rod) 90240-08006 $1.80
Bush (for Clutch master cylinder push rod) 90386-08036 $2.31
Clutch Master cylinder to flexible hose tube 31481-53060 $9.61
Clutch No.1 Hose 90947-02c83 $41.05
Clutch Master cylinder to 2 way tube 31481-53051 $15.26
Clutch Release cylinder to flexible hose tube 31482-53030 $7.47
Flexible Hose Bracket 31484-53040 $9.28
Clutch Pedal Support Sub-Assy 55107-53030 $55.18
Ring 90082-61005 $1.62
Washer 90206-08001 $0.98
Bush 90386-08036 $2.31
Clip 90468-16142 $0.95
Washer 94622-11000 $1.42
Bolt 90080-11497 $0.77
but you have to realize thats dealer price, and they made a shit ton of manual 7th gen celicas. i found pedal sets as low as 85$ a set.
Thread Revival
So is this pedal set a viable option for the IS? All the thread shows is parts/ cost. I'm currently collecting swap parts and the IS pedals are hard to come by. The CD009 was the easy part.
Bump for more info :popcorn:
