I'm having a problem with front passenger side door lock and window its killing me trying to figure this out.. Driver and both rear doors work. Passenger door lock's and unlock's with driver switch and remote but not with passenger door. The window does not work with driver or passenger switch.
I have taken the door panel off and put power to the window motor and it does goes up and down so the motor is good. look and look and look at wiring diagrams and window switch wire color dont match up with any i have looked at. IS is a 2003
Any assistance anyone can provide would be greatly appreciated.... Thanks
But a voltmeter on the wiring and see if you get power. Trace it back. This is assuming you checked the fuse and tried replacing the switches.
The door lock same thing.
The switch work's put on back doors works just fine.. I'll check The fuses again just in case I have miss something and meter everything when the rain stops..
