I had just recently got my front right fender, front passenger door fixed, and my quarter panel knocked out. Everything on my front passenger door works except for the side mirror. I tried switching it to adjust the mirror and no response. any ideas?
Hi Kritiq,
I am curious if you got this sorted out? I had my right front door removed as well and the SAME issue has happened only neither of my side mirrors work.
Did you find the solution? Was a cable just not plugged in, was it a fuse blown?
Thanks!
heybmcgill
Hi Kritiq,
Thanks!
heybmcgill
There's only one fuse that feeds the power mirrors and that's the Radio#2 fuse. If that fuse was blown, you would have other things not working in the car such as the radio. If I were you(and since you lost function of both), I would pull uo the switch assembly and make sure you have power(the only grey wire) and the ground wire is grounded, which is a white w/black stripe wire that grounds to the front left fender apron and cowl panel left side.
