I have an altezza 3SGE 4CYL. Can I use the timing belt, drive belt, oil filter, air filter and other service parts for the IS300 - 2JZ-GE on my altezza? Also in general can parts for the latter be used on the former?
Any information is greatly appreciated
NO you cant. I think if you use parts from the 88-89 3SGELC Celica GTS you might be alright. Here are the part numbers for the Celica:
Timing belt: 13568-88381 (not sure if its still avail)
Alt Belt: 90916-02293-77 $27.85
P/S Belt: 99363-70760-83 $10.36
A/C Belt: 90916-02116-78 $15.04
Oil Filter: 90915-YZZF1 $5..41
Air Filter: 17801-74020 ( I kinda doubt this would fit the Alteeazzza)
I just check and I only say 2 belts at the front of the engine. Above you listed 3 (alt, P/S and A/C). Could you please help me out on this one?
nautox, I understand that the engines are different and as such uses different parts. However is the body parts such as control arms, shocks, rotors the same for both vehicles?
brakes and air filter are the same, as well as most suspension parts and axle back exhaust
Discussion Starter #7
Respect Chado for the information. One more thing though, does the the 1G-FE 6CYL and the 2JZ-GE 6CYL uses the sames engine service parts such as oil filter, timing belt and drive belt?
