I need to get a complete parts list for timing belt maintenance.
Now I already have the titan cam gear on order and am planning on BC 2 Cams, Unorthodox light weight accessory pullies and undredrive crank pully,
shewwa, now that I have the important stuff out of the way
what is the best place with good parts to get a complete timing belt replacement kit that has, water pump, timing belt, timing belt tensioner, accessory tensioner, accessory belt all the seals that I need to replace and so on... Besides the stealer.
Thanks
Scott
TIME:
- 5-6 HRS
TOOLS NEEDED:
- 10mm Socket Wrench
- Breaker Bar
- Chain Wrench
- Modified 10mm Wrench
PARTS NEEDED:
- Timing Belt: Part No. 13568-49036
- Tentioner: Part No. 13540-46030
- Idler: Part No. 13505-46041
- Drive Belt: Part No. 99366-D1930
- Water Pump: Part No. 16100-49876-83
- T/Stat: Part No. 90916-03093
- T/Stat Gasket: Part No. 16325-62010
- PCV 5/2000-5/2001: Part No. 12204-46030
- PCV 5/2001 and up: Part No. 12204-46031
- PCV Grommet: Part No. 90480-18001
- O-Rings Bypass Pipe: Part No. 96761-24022 (Qty=2)
- O-Ring Bypass Outlet: Part No. 96761-24028
here is the perfect answer.
Thank you for your Support,
Thanks
Scott
You might want to search that underdrive crank pulley. I've read that it removes the harmonic balancer and can do some damage (due to vibration sans the balancer).
