1 - 2 of 2 Posts
HI, I'm Jonah. I am a new owner in Indiana. I have a silver 04 Sport cross that is kinda a daily driver project car. How do you remove and replace your front and rear parking lights, dimming mirrors as well as rear hatch actuators?
Assume you mean park light bulbs? It should be the same as any other car, the rear blulbs are accessed through the access "doors" in the inside boot trim behind the lights. Fronts are accessed from behind the headlight in the engine bay, if you look at where they are in the headlight you can pretty much see where the connection is to the back of the bulb. Twist and pull to remove.
Not sure about the dimming mirrors and actuator. Probably best to download and look through the workshop manual.
1 - 2 of 2 Posts
