1 - 10 of 10 Posts
I have a 2007 is350, and I am curious as to how often others use the paddle shifters. In my daily commute here in So Cal I rarely use them. I ask this because I have signed up for the track event in Fontana May 30th and I am attempting to use the paddles more in preparation for that day.
On a track day I would recommend just leaving the car in power mode, the paddle shifters will just be an unhelpful distraction.
I've never used mine. I guess I'm lazy.
Supposedly at the track, the car is slightly faster if you just leave it in automatic mode and stomp on the gas.
No human can shift as fast as a computer.
If it's a drag track, just leave it in S (since you don't want it going higher than 4th)
If it's a not-in-a-straight-line track then there might be some benefit to using the paddles, but keep in mind they're not really shifters, they just set a top gear limiter on the car- the car won't hold the gear you select like a "real" shifter would.
I agree auto's will most always shift faster than a manual. But the Lexus track event is a road course and I think we will be paddle shifting the IS-F the majority of the time. See the link below.
https://www.tasteoflexus.com/performance/faq.asp
I use the paddle shifter when I am being enthusiastic around town. I think if you were doing a road course it would benefit you to do the shifting from the shifter. You might have the wheel turned a bit and need to hit the up or down shift so the shifter would be more intuitive. I have not taken my car on the track yet but that is just my 2 cents.
I use it mostly for engine braking and also to be on the power band coming out of a curve.
Note that the shifter in the IS-F is -completely- different from the ones in the ISx50.
It's a -real- shifter, not just a top gear limiter... and could certainly be of a lot of value in a road course.
i always drive in sport mode, but ONLY so i can downshift to slowdown or maintain a speed downhill. try to avoid brake dust as often as possible ;)
as for the track event, not sure. all i know is in a drag autos the best.
Off topic but, I took my 350 to the dealer and had the front pads replaced with ceramic per the TSB and brake dust is no longer a problem.
1 - 10 of 10 Posts
