Diagnose Check Engine Light Codes, Emissions And Oxygen Sensor FaultsIntake Cam Position Actuator Circuit Open - Bank 1
Description:
How does a P0010 code trigger the check engine light? This code will trigger the check engine light under the following condition:
The comprehensive component monitor, referred to as the CCM, monitors the Variable Camshaft Timing (VCT) circuit to the computer for high and low voltages. If the voltage falls below a set limit for a specific amount of time during this test, the check engine light will come on and set this trouble code.
Possible Causes:
Open or short in the VCT circuit
Open in the Vehicle Power circuit
Open or short in the VCT solenoid valve itself
Damaged computer (PCM)
Diagnostic Help:
This check engine light code is caused by a circuit fault of the VCT system. Testing should include all related wiring circuits, the VCT solenoid and PCM itself. Please refer to out article on Automotive Circuit Testing for help with this. You may also use the "Get Help" link if you need specifications or have any other related questions. Remember to refer to an appropriate manual for specific instructions.
Yea, I figured you read it. Just thought I would post for reference.yeah i read that too...
i was hoping someone else had to deal with this and i could get a definite answer of what it was/is
my AEM has nothing to do with the OCV.I'm sure you checked your plugs/connectors, so my only guess would be if the AEM is setup to run VVTi. If so I would think it would be wired in a way that puts the OE ECU out of the loop (PWM wire probably cut within the ECU box), and an open would be sensed. Find the wire in the PNP harness for VVTi and check it out (E5 and E6 in the ECU pinnout floating around here).
The Dezod AEM controls VVTi, thats probably your CEL, the OE wires are cut, and the AEM in direct control, I'd bet its an "open" its detecting.the one from dezod 1.19. does the code mess up timing an any way?
That doesn't sound like a sensor to me, but the actual actuator, which would be an inductive mechanism of some kind, be it stepper motor or whatever (I believe its a PWM signal). It (OE ECU) has a detection circuit for an open or short condition, apparently. Would suck to get rid of this CEL with a resistor and then get a different one because it also has a feedback logic kind of like closed loop.Intake Cam Position Actuator Circuit Open
I'm doing what many of the no-longer-here OG'ers hated. Since obviously there is not help, I am provided an idea, a hypothesis, a route for the average DIY'er to explore and rule out. It simply makes senseso you think this is normal with the dezod AEM since its controlling vvti?
