1 - 10 of 10 Posts
Hey all,
Does anyone have pics of custom door panels for oversized or double woofer front stage setups? I'm still throwing around ideas, and some of the drivers I was looking at were 6.5"-7" diameter and 3" mounting depth.
I wasn't sure if the is300 doors could accomodate that size w/o custom work done.
If anyone has some pics of your custom doors, or a cost estimate on what it took to get it done, please post! Thanks!
Threadlocker
someone on here showed a pic of their custom door set up a few months back. two woofers in each door? dang can't remember the user name but it was a blue car if i remember correctly.
Useless
I beleive its unVme that has custom lower doors accomodating multiple drivers as well as kicks with mids/tweeters.
The IS can easily handle 3" depth as well as a 7" woofer. The woofer will fit behind the door panel, but you will most likely lose a little of the surrond area at the door panel opening. Build baffles to hold the drivers and include a small flush mount lip so the woofers excursion does not drive it into the door panel.
I can fit these with no problems!!!!
http://imagedynamicsusa.com/tech_page.php?name=CXS62&type=midrange&id=chameleon
They have a 6.6" speaker mount requirement as well as a depth of 3.125".
^that's good to know, I'm sizing two diffeent drivers right now, one is 7"x 3.3" deep, and the other is 6.5" by 3" deep, a little more do-able it seems.....
Here's UnVme (Matt)'s setup:
Best pic I could find of his door:
And here's one pic of Turnip (Tyler)'s door panel:
both of those setups look sick, turnips looks just like what I would like to do with my interior minus the kicks.......what kind of speakers are those?
Discussion Starter #8
wtf turnip! That sytem is crazy!
My goal when explaining to my deisigner was to keep the LINES on the door as factory as possible. Look at the door...It looks like a factory door panel with speakers and plexi added in..The WHOLE entire door was custom but doesnt appear it.
Hope the new owner is happy those doors took 3 months to perfect and when the door shut it sounded firm and not flimbsy
-Matt
3.125" speaker depth drivers with 1" baffle on stock looking (stealth) door panels. I had to shave a little plastic so it didnt make any noises when i rolled up and down my window..
1" baffle
1 - 10 of 10 Posts
