I was driving around heavy traffic today and i was following big semi truck. I was on the hill behind this big semi truck going like 5 mph or less and i put it on the 1st gear and it made metal grinding sound TWICE!!! Is it ok? is that the gear that's grinidng or what?? CUrrently i have about 1500 miles
Did you depress the clutch pedal??? :-?
If yes, it is not normal.
that's weird, it shouldn't grind, you should only feel a wall blocking the gate. Are you sure you had the clutch depressed all the way?
I'm not postive sure because my foot was tired. YOu know what i am talking about in the heavy traffic situation. ALso IS300 clutch pedal is pretty heavy too....well i'll check it with Lexus Dealer
