Okay, I was able to get some time in on the install. As I am mounting the turbo to the manifold, I notice the oil drain is positioned right on top of the manifold. So I clock the thing over so its slightly angled to the shock tower. I go to put the housing on and I notice it is very close to the oil drain. So my question is:
how do you guys protect your oil return line from burning up? Do you wrap the hose with some type of heat resistant material? I can divert the hose away from the manifold/turbo housing via a loosely mounted guide against the body of the car, where the ABS bracket use to be. Here are the pics. That small piece of blue tape is wrapped around the spout:
My turbo Gremlins..
My turbo Gremlins..
