I searched and searched and searched still no answer just a bunch of suggestions to take it off. Any ways i'm getting ready to tape oil return line but i need to take off the oil pan. Does anyone know any post somewhere or anything that can help me out. I would greatly appreciate it.
i would just use an exacto knife or a razor blade... its just fipg holding it in place minus the 10mm bolts that surround it.
You can loosen up the 2 engine mount nuts from the top, or take them off...then lift you engine up an inch or two. You should be able to get a wrench on the back of the oil pan at that point.
i was trying to figure out a way with out that. My bro and i talked about it i think he's going to get a steel rod and weld a 10mm socket to the end. Should be thin of enough work.
