MNSpectraBlueIS that the info I wanted thanks for the link
MNSpectra says:
[RANT] WHY must every manufacturer put the oil filter in such a position that it drips all over everything when you remove it? I had a rag under it to catch some, but I still ended up with a puddle on the floor and oil all over the engine compartment under the filter. WHY WHY WHY???? The only sane filter mounts I've seen have been on a '96 Blazer and a '83 Regal. The Blazer was right up front at the botton where it didn't drip on anything else. Oh yeah, and don't spill any around the oil filler hole because you can't clean it up with the big plastic shroud around the engine. Spilling here is a little easy because the filler hole is right-angled and not very big (inside)[/RANT]
I agree, my LS1 (GM) engine had the filter next to the oil pan drain plug straight & vertical. I would fill the new filter with fresh oil berfore spinning it on. Very very easy! Why can't they all be this simple?
[ July 06, 2001: Message edited by: mjdart ]
[ July 07, 2001: Message edited by: mjdart ]
