hey
i was on the phone a few weeks ago with a rep for champion toyota (jeff watson). i was looking for a bango fitting to tap oil feed from VVT-I oil line.
i was told to not take away any oil from the VVT-i as it needs as much as it can get, and that i should tap from oil pressure sensor. now i know many of you guys are using this setup. any problems ??
thanks.
Virgin Magnet
why would you do otherwise (than the oil pressure sensor)?
the oil pressure sensor all you need is a 1/8" npt fittings and you have an npt oil feed line port?
shorter line....??.donno. just saw some post about vvt-i hook up. though i'd ask.
thanks for the reply:)
