you know i hate changing the god dam oil haha.. well just the filter part.. what do you guys do or find the easiest to take off that dam filter?
I believe there is a write up on this.I bought an oil filter relocation kit from JC Whitney that will cure this problem. Can't wait to install it the next time I change my oil.
Plugs aren't as bad as it seems. There's even a step by step on the forum with pictures somewhere as well. But, back to the Oil filter, it is a PITA to change it. I'm going to order the relocation kit before I change my oil next as well.I'm a newbie, but Ive already changed the oil in mine once. It's not near as hard as some of the people say. It's a bitch and you might get dirty but it's not that bad. I pulled the drain plug, then nudged the motor to the passenger side, slipped the old filter out the top. Takes a few seconds to figure it out but its simple, and alot cheaper than having Toyota dealership do it. I did the same to get the new filter in. Im NOT looking forward to changing plugs though.
Me too!I bought an oil filter relocation kit that will cure this problem. Can't wait to install it the next time I change my oil.
