I have a 97 supra NA and I am considering changing the motor to a 98 VVTi. Either way, the 97/98 are both OBD 2.
I have a full turbo kit ready to install, can you tell me what tuning troubles I can expect running mafless with greddy emanage ultimate and the OBD2? I have 440cc injectors (need resistor info). The emanage ultimate is what I have. Nothing is installed yet. I will have no other electronics other than the stock ECU, except maybe a profec e-o1, but I prefer a MBC.
Thanks for the help.
-M
why would you want to swap to a vvt-i motor? It would only cause more headaches when tuning
my 2psi
a tt shortblock is the same as an NA shortblock except for these differences:
TT has oil squirters, different pistons, and a different oil pump. All else is the same.
The long block of course has a different head and intake.......
I want the VVti. I have an OBD1 computer to replace the OBD2 if I wanted to stay with the 97 block. If I go to the 98 the ECU is too different and cannot be swapped.
Keep the ideas coming, thanks!
Podiatrist
your ecu needs to be able to control VVTI.
Otherwise it just wont work.
I have the complete head, harness and the ecu for the VVTi. Was going to do it, but I don't think it's worth the effort for the VVTi feature alone.... So I am keeping the stock head for my build.
-M
