does anyone know how to wire one of these up.. i bought a used one that has 4 wires. 3 on one side and on on the other. i believe that it is the one that can be wired up parallel. i did a search and came up with jack. TIA
02 sim
If you do a search using 02 sim I think thatyou will find it. Is your car a 01 or 02 I think it makes a difference. I will look around and see if I can find my drawings of it.
Good luck
Russ
Brown spliced to Brown on upper o2 sensor connector not sensor
Black spliced to Black/Red on upper o2 sensor connector
white cut to to white sim wire on upper o2 sensor
blue cut to blue on rear sensor on y-pipe.
I found this using search. I think it is for a 01
Russ
when i did a search i did not find anything. i probably didn't type it in right. thank you for your help. i will check tonight to see if it is the sam for an 03. again thanks for your help.
jeremiah
