Status
Not open for further replies.
1 - 1 of 1 Posts
Lower from 1.2" to 2.4"
KW Suspension has released the Variant 3 Coilover for Lexus IS250/350. The Variant 3 coilover allows you to lower your Lexus IS250/350 from 1.2" to 2.4" (30-60mm) on the front axle and 1" to 2.2" (25-55mm) on the rear axle. The individual height adjustment gives you the option to set the stance you want. Even at a 2.4" drop, the Variant 3 was designed to have enough travel to handle the maximum and dynamic driving loads.
Separate Rebound and Compression Adjustment
The Variant 3 has a patented 2-way compression valve technology with individually adjustable rebound and compression dampening settings. By allowing you to adjust rebound and compression separately you are able to fine tune the ride to fit your driving style.
Inox-Line Stainless Steel Technology
The Variant 3 uses unique "inox-line" stainless steel technology. The stainless steel construction internally and externally provides long term durability and corrosion resistance. All KW coilovers pass stringent German TUV safety and quality testing standards. Each kit is sold TUV approved.
Click here to find out more about KW Variant 3 Coilover.
This PostRelease® is part of an advertiser-supported program that sponsors My.IS. This program delivers relevant news and announcements as posts within the My.IS forum. If you have any questions or if you're interested in using PostRelease on this forum, click here to contact PostRelease.
1 - 1 of 1 Posts
Status
