After replacing the head I am experiencing issues when trying to start the car. When I turn the key, the car does not crank. The battery is good, I do not hear the starter relay click or anything (starter itself has been jumped and is confirmed to work and I have cleaned up the connections). The security blinker is good. None of the sensors on the engine seemed to be unplugged. Fuses and relays do not appear to be bad or blown. The car cranked up before the head replacement. I suspect the ECU itself does not want to send power to the starter for whatever reason. I have scanned codes and got nothing.
The only thing I hear when turning the key is the fuel pump.
Is there something that I am missing to check?
What sensors may cause a no-start if unplugged?
Can someone elaborate on the neutral safety switch?
