61 - 80 of 115 Posts
If you build like me (when I do eventually go turbo) you could do it in steps like this
1) boost on GE till about 300whp.
2) swap in GTE internals and R154 or V160/161 and then go for 400-500whp.
If my current e-shift trans is built with SRT's parts (trans cooler, sprag upgrade, valve body) what HP would you guys say my trans is good for? Considering adding performance torque converter, just haven't decided if i want to spend the money on one or use that money for a R154 swap. Pretty sure V160 is far too expensive for me..i haven't even looked into the price of a trans swap...$$$$
Please don't buy a kit like this if you know little to nothing about turbo kits and what it takes to properly run a turboed IS300.
You should at least have a backup car. Also, buying used parts is better than buying that crappy ebay kit.
im looking at purchasing the srt kit and want to also install pistons and rods. but i want to stay in the 8.5/1 compression ratio range. what pistons would i need to accomplish this and ik the kit comes with a thicker hg. could i just buy forged pistons and rods that are exact same as oem that are just stronger?? and use the thicker hg?
or would it also be possible to run gte internals on this set up?
no matter what with forged internals you will have to get your block machined. also you can have any compression you want you just have to buy the right pistons and the thicker headgasket will help that. GTE internals will be perfect for that kit not to mention a lot less money.
It sounds like you need to do some research on turboing an IS300.
I don't really like the SRT kit, plus it might take a while for you to get it (do some research, some members don't receive anything from them till a long while).
GTE internals will work with any turbo kit......I don't see how its even a possibility that they wouldn't...
i have a problem with searching on this sight ik there is alot of info but i seem to cant find what im looking for. all im asking is what hg i need to run a 8.5-1 compression ratio on gte internals
whats wrong with the srt kit?
Well for some people it takes them awhile to get your stuff from mo at srt. But i'd say you wanna run 8.5 - 9 compression ratio. its all about what you wanna spend and how much power you wanna push and how much torque you want, thats the main part that came into mind in my head by making sure all my stuff would hold the amount of power i might wanna try to reach. trust me its a money pit man so be prepared for extra costs
The safest options are:
1) GE internals w/ GTE head gasket
2) GTE internals w/ GE headgasket
3) GTE internals w/ GTE headgasket
The third one is the safest but the other ones are fine. The GTE head gasket is 1.3mm thick I believe so you could find thicker ones and run them with GE internals.
Things I don't like about the SRT stage 3 turbo kit:
1) you may not get it anytime soon even if you pay now.
2) The SRT Spec'd Precision Billet 6266SP is too big for what I want
3) The "large 50mm wastegate" is a POS - wastegate is somewhere where you want quality
4) SRT 1000cc injectors are wayyyyyyy too big for most people
5) I could spend the same amount of money and have a kit build to my specs, not theirs.
^if you're car was properly maintained there shouldn't be a problem.
Do the necessary compression and leakdown test and then you'll have a good idea about what shape your engine is in. Find a shop that has experience with the 2JZ and ask them to perform these tests. They'll be able to determine whether or not your engine is boost ready.
How much hp will this turbo make?
I'm peicing together a turbo. I'm getting a Garrett from a friend which I've seen but don't have the serial number right now. I have a turbonetics. Here's the specs of both turbos.
Turbonetics T60-1 t4 devided. With a .70 a/r exhaust. I forgot the a/r of the compressor. 3" inlet 2" outBig it's the old schoil one with blue back plate. Used for probably 20k miles.
Garrett turbo. It's a upgrade for a 7.3l diesel truck. Has a .84 a/r twin scroll t4 housing with a compressor housing of a gt30r turbo. 2.5" inlet 2" out. Brand New
I want to swap out the garretts compressor housing wheel and back plate for the turbonetics one. Balance the turbo also.
How much hp can I make?
emange ultimate, 850 or 1000cc, aeromotive fpr, dual aeromotive pumps, gte rods and pistons, brian crower cams, gte coilpacks. pump gas 93 or e85. srt log manifold, 3" turboback exhaust.
