21 - 40 of 115 Posts
Use the search function! Many guys are running this kit. It's worth the money if you know nothing about turbos. If you can shop around you will build a kit for less than that. Don't forget that buying this kit is not the only thing you will buy to go turbo.
If you are only going to run 350RWHP then yes it is everything you need. More than that than you are looking at internals, and building up your tranny, or a tranny swap.
im piecing together my own kit, i would go with what madchyers said, its exactly what i am doing. although i did get a xs power turbo from a SC300. havent finished getting all the parts yet so i can't tell you the end result. don't forget to upgrade your fuel system too.
here is a link to some rebuilt turbos, i almost got one, these might be a little big for your goals tho, im not sure.
http://usedturbos.net/Catalog/index.php?option=com_virtuemart&page=shop.browse&category_id=18&Itemid=53
Also check into running a Holset turbo off a diesel, its popular, esp among the supra guys from what i've read. you can get em pretty cheap too. you just have to weld the internal waste gate. some one correct me if i'm wrong, this is just what i've read and been told.
Some people do guy, its capable. People see it as a kit to buy and not piece together, but not have the funds to do the rest. It just like everything else out there that gets pieced together, just some different parts, and a shitty wastegate that comes with it
Super Moderator
Save your money , prepare for boost (maintenance) and buy parts as you go and put together a better kit then going with full ebay option.....
or post 4 more times and see the 'for sale' listing. haha
I'm using pieces of the club NA-T / XS power kit. I have about 1000 miles so far no issues. The kit is very incomplete , the down pipe that came with it went in the trash, the manifold works but had to move the break lines out of the way , lots of fabrication went toward making everyone fit . At low boost no complaint. I had a professional instal so they pretty much rip the kit apart and replaced some things. I took the 13lbs spring out and put a 8lbs spring fromtial. I think the turbo manifold and wastegate are okay at low boost. The kit is just the manifold,turbo , wastegate ,BOV, and some oil feed lines and fittings . You will have to purchase everything else seperately. Get SRT if you can. My build could of been a train wreck if my shop didn't know what they were doing.
i thought this kit comes with everything you would need to turbo an is300... ?
Read a couple posts up, I have already answered that.
Yes it is everything to go turbo.
But if you are looking for more than 350RWHP you need to uprade other things to your car. That being said it is not everything to go beyond that point.
NEED HELP! Is this good or not?
I have a 2005 is300 with 60,000 miles on it. Its an auto and I have wanted to boost it for the longest time. I don't want a monster just something fun to drive around. I have a little knowledge about boost but nothing major. After talking to a few people they recommended me a shop and this is what they sent me. My car is currently all stock and i need to know if this is a good deal, will it hold up, any flaws or concerns you guys see? They have said it'll take about a week. Thank you guys for your help!
From mechanic: The entire kit I can get for $2100. There are cheaper kits out there but I wouldn't be able to warranty them. The cheaper ones use universal fit parts that have to be cut and modified to fit. Also they are a lot lower quality and may crack under high temperatures. I'm only charging $1000 for labor since you were referred by another customer of mine! If you would like the car dyno tuned i would be able to that for an additional $1000! What i mean by this is computer and engine management by Greddy or the use of an SAFC. If you would prefer something else we could do that also. Dyno time would be included in that and would probably need the car for several more days to make an appointment with our dyno guy! The kit will be ok to drive on without the tuning and will be safe on low boost. The tuning is to get the maximum power on your setup while maintaining reliability for daily use. If you dont have the cash to do this right off the bat your setup will be just fine without the fine tuning!
TURBO KIT INCLUDE :
Lexus IS300 Front Mout Turbo Intercooler Piping Kit(JDM Sport)
Intercooler Piping are CNC Machine Mandrel Bent (Jp Design)
Made From High Quality 6061 Aluminum Material with Black finish.
Extra Thick Piping and Increased Air Flow
Light weight design. Made from Aluminum.(Increase 10-20 HP).
All TIG Welded 6061 Aluminum.
PSi Drop under 0.2. Other Intercooler usually drop 10Psi Some are More.
Comes with 4x Turbo Pipes, T Bolt clamps, Couplers and Various Accessories
Pipe comes with RS/S Type BOV flange already prewelded.
JDM Turbo Front Mount Intercooler (Godspeed)
Light weight design. Made from Aluminum to increase 10-20 HP.
Size: 28"x7.5"x2.5" Core: 21"x7.5" with 2.5" inlet/outlet
LEXUS IS300 2JZGE Stainless Steel Turbo Manifold (Godspeed)
High Quality T304 Stainless Steel material with CNC Machine Made
Made to withstand high temperatures without breaking.
Direct Bolt on to the block
Best Fitment with T04B T4 Turbochargers and 40mm or 50mm External Wastegates
T04B Wet Floating Bearings Turbocharger (Godspeed)
Oil Cool
CNC Machined Flanges 4Bolt Designed fit most After market Mainfold.
25 to 35 Psi Peak Power Performance Output Capability.(factory warranty).
Designed Usable for External Wastegate Applactions only
Compressor Specs:
3" Compressor Inlet
2.128" or 54.06mm Inducer
2.752" or 69.91mm Major
2" Compressor Outlet
Compressor .50 A.R.
Compressor 50 Trim
8 Blade Propeller Type
T4 Compressor Housing
Turbine Specs:
T4 Type Turbine
T4 4 Bolt Flange
2.539" or 64.50mm Exducer
Turbine 1.15 A.R.
Turbine 70 Trim
2.880" or 73.16mm Major
T4 Twin Entry Turbine Housing
LEXUS IS300 2JZGE Stainless Steel Turbo Downpipe (SSA)
Direct Bolt on to the Exhaust
50MM External Wastegate(JDM Sport)
CNC billet aluminum T6061 housing for heat disbursement
4 Bolt Flange set up for turbo applications.
Inconel base housing with forged stainless steel valves construction
Heavy duty actuator diaphram withstands temperatures up to 490 degrees celcius
High temparature silicone reinforced actuator diaphragm inner design
Weld-on flanges are included with every kit.
Wastegates includes steel hardware bolts.
Boost adjustable with use of any high performance boost controller.
External wastegates are commonly used for fast spooling and keep back pressure to a minimum and still regulating boost levels more precisely than internal wastegates in high power applications, where high boost levels can be achieved.
RS Type Blow Off Valve
This Blow Off Valves Are Easily Adjustable To Prevent Both Premature Boost Leakage And Compressor Surge.
The Spring Stiffness Adjustment Screw And The Two Different Size Give The User The Option To Match Vehicle
With Mild Upgrades To Heavily Tuned Engines
It Can Hold Up To 1200HP Or 25 PSI Of Boost Pressure
For All Turbo Application
Turbo Feed Oil Line Kit (Alliance)
Made Out of High Quality Aluminum
Oil Feed Line for turbo
Improves Turbo Oil Cooling for all Engine types
Steel Braided to withstand High Preussure and also withstand Extreme Heat
1/8 NPT Fitting as require for Most TO4B Turbo application
Oil Drain/Return Line
Oil Return Line made for turbo
Helps circulate oil from the turbo to the oil pan
All components are included for fitment
Steel Braided for Maximum Durability
10 AN Fitting as require for any Turbo application
Ok, ill go through the links after work, but im looking for opinions and availablility on kits.
Ok, Turbo kit recomendations thread, last post 2007 and not a single kit recomended? It shows supporting mods, Im looking 300-350 rwhp. Links to places that make them, if they still do?
Talk to the CEO of SRT, hes a big help on questions you may have. Best company (imo) is SRT for easy 300-350hp is300. email is right here for you :)-->[email protected]
Cheap Quality Turbo Kit
As the title states, I am looking for a cheap turbo kit that still is of good quality. I have been wanting to get the SRT turbo kit but they are running around 6k, and at this moment I do not have 6 grand to spend on a turbo. If anyone has had any luck with a cheaper kit I would greatly appreciate the information.
Thanks,
Robert
Before you get flamed--
IMO the people that ask this question inherently cannot have this request- let me explain.
There will be those that would say what you want is impossible, or a catch-22. I believe what they mean, is that if you have to ask, then you do not have the capability to pull it off.
The kits that are pricy, are not pricy because they use over-kill top of the top shelf parts, but have had the foresight and experience put into them that they work darn well. They are application and time tested.
To do it cheaply- it is somewhat possible. But there are two types- those who pull it off because they have the knowledge, and therefore do not even have to ask where such a kit is, or how to build one. Then there are those who ask, get pissed when people give them good honest advice that is not what they want to hear, and then for the next year we follow their build thread of epic fail as almost every part they buy fails, performs badly or simply won't do the job and they make constant mistakes be it wiring, bad sensor placement, bad component placement etc etc. And then they end up paying just as much over this period of time to make it work as it would have costed to do it right the first time, and/or the car gets put up for sale.
So one is left with two options. 1) pay to play 2) buy some books, do a lot of studying on the subject and become capable of doing it yourself- and in the process learn why those who can, do not roll out the red carpet for those who can't or 3) Jump into it and 'fall down the stairs' into pain so to speak.
Don't get me wrong, there will be those who said they bought "X" cheep kit and everything is great, but take everything with a grain of salt-- they may have a lot of ability, lots of little odds and ends in their garage that for those who don't, it adds up- they often have a mechanic friend or family member, can weld, have awesome fabbing friends, friends in the industry etc, and for all we know they got a great kick-back when buying the kit/parts and they are simply talking it up for that reason. Anyhow, do enough searching around here and I doubt you can refute these points, but rather totally agree with them. If you have the luxury of learning the "hard way", then I say go for it-- its great to learn, and your better off in the end gaining all that knowledge than not at all.
