Its not as bad as it sounds, I did a front rotor and pad change (using OEM) I changed cause of previous warped rotors.
Also changed the passenger side Ball joint, everything is good no wheel shake but there is a very very slight grinding/vibration in my break pedal, I’m thinking they just need to be warn in?
anyone else experience anything like this?
Discussion Starter · #2 · (Edited)
Took it for an alignment, turns out Lower control arm bushing is shot, now I’ve just searched and no one makes a bushing for an IS300? wow weak..
so my options are a $1600 kit from L-TunedParts
or
New control arm from Lexus $215.50/each
slim pickings, very disappointed.
or
You can get the used decent ones in here for cheap.
Used bushings :/
how about some custom bushings, I own a machine shop, making some bushings is a joke.. just where do I get Poly? or maybe another substitute of urethane that will work?
where can I get those used ones?
Used bushings :/
Try looking in the FS section. Sometimes some members carry the open-box brand new items. Frequently check there...
