1 - 12 of 12 Posts
Its time for some new tires and I need soem help. I got it narrowed down to three all season tires. Im looking for the BEST tread life while still having good dry/wet performance of the three. I dotn care about snow cause i have a snow tire.
They are:
Toyo Proxes 4
Kumho ECSTA ASX
PIRELLI PZERO NERO M+S
Thanks for any help you can give!
They are:
Toyo Proxes 4
Kumho ECSTA ASX
Remember tread life and wet dry traction are oposite of each other. It is like saying, I need the most expensive cheapest widget you have. Wet and dry traction is functional upon the tread wear which is in the form of a number on a tire. Example my tires are a 300 treadwear.
http://www.tirerack.com/tires/tires.jsp?tireMake=Pirelli&tireModel=PZero+Nero+M&S
http://www.tirerack.com/tires/Spec.jsp?make=Pirelli&model=PZero+Nero+M&S
In a 400 treadwear on a 215/45/17 this tire should be fairly sticky. It is also an A for wet traction, not a AA and has an A for heat dissipation. Read the reviews on each too. I am not sure how your climate is, so you may have to do a little more common sense research. Hope this helps.
Pirelli Pzero Nero. Excellent tire, I replaced my dunlop sp 9000's with these. Very good traction in the wet and snow, acceptable for the summer.
thanks everyone for the help. I liked the Pirellis too, but i am a little concerned about the A traction rating. So i guess i am still not sure which one to go with.
Virgin Magnet
03sport said:
BFG G-force sports
traction AA
treadware 340
$113 a piece for 245-15-ZR17
yeah those are all season
another tier to look at but i thinkits a bit more money than you want t spend - yet still coming down is teh micheline pilot sport a/s
but of those listed i woudl go for the pirelli - good tire
I've had my nero's for 2 years 25,000 miles on stock rims and this winter im going to 18's the wear is good considering I like to corner hard, can see the wear inidcators though. Im going to stick with the nero's when i change my rims, excellent tire.
I've got ALMOST 28k miles on my car and getting ready for my third set of tires. The rear tires wear like crazy. ;)
1 - 12 of 12 Posts
