So I slapped a brandy new set of tein CS's on my car a few weeks ago, but this has been bothering me. Ride is excellent btw.
I left them at factory settings until I put a few miles on them. Now I go to adjust them. I adjust the rear first. Set it up to have a 1 finger gap on both sides. The driverside rear perch ended up pretty tight so it took some force to higher it up and spring is very preloaded now. Passender side rear I was able to turn by hand, and there is no preload on the spring, BUT car does sit even in the rear when I was done...
Moving on to the front of the car, thankfully the wheels dont have to come off, I can just cut the wheels and reach around to adjust these. Now here is the wierd thing... the Driverside front I was able to adjust by hand to get the one finger gap, with almost no load on the spring. The passenger side needed some force to spin the perch up and preloaded the spring alot. SOOO, basically what I got is a car that sits evenly, but preloaded on opposite corners of the car. Seems fubar to me... handling wise seems to be fine after cutting the wheel left+right and distribution feels equal...
Any ideas as to why this may be? These coil are put together from the factory and everything was tight and even when installed. What the heck.
