I just recently installed BC Racing coiolvers on my 300 and went to get an alignment done. The tech at Firestone noticed that on the rear left side the metal part against which the camber screw turns is all bent so the camber screw can't turn properly. Apparently the only reason the camber was OK before is because the screw was actually sitting on TOP of the metal part... which is crazy. So right now I have some negative camber in the rear left wheel that needs to be fixed. They quoted me about $150 to try and fix this problem or the tech said that I can purchase a camber & toe kit and replace the arms so that i don't even need that camber screw at all. So i figured might as well take advantage of the opportunity and upgrade some parts. I was looking at the Megan parts and was wondering if these will fix my problem:
Megan Racing
and / or
Megan Racing
Any other suggestions would be appreciated.
Megan Racing
and / or
Megan Racing
