i was took out the bottom rear seat and when i went to put back the seat it wont stay on the snaps tight if you put your hand under it the seat will pop up anybody know what to do?
If I understand your question correctly, then you just need to push a bit harder to get the rear of the seat up under the seat back. That solved that problem for me when I had the same issue.
lexluger180 said:
the two things on the front dont snap back in :-? i dont really know how to explain :crazy:
Look at the seat bottom and you will see the two extender bars on the back. Those slide up under the seat back cushion. If those are not slid far enough under the seat back, it will cause the seat cushion to pop out of those connectors under the seat. Does that make sense?
