41 - 53 of 53 Posts
Discussion Starter #42
well i got it started.the JB Weld held up. the crank timing gear was the issue. there is an issue tho, the battery light is on and i cant figure out why. i have a complete charge and the car does not die so the alternator is doing its job. so what could be the issue?
Super Moderator
The battery symbol is an indication that the charging system is malfunctioning and not charging or registering a charge. Make sure the 3 wire harness is connected to the alt. You will need a multimeter and follow my tutorial below. You should have 13.2-14.8 volts at the battery while running and a battery off voltage of 12.6v or higher. The battery symbol will not come on if the battery is dead, only if the car is not charging and voltage is at proper level. I would check to see if you have +12 to chassis/ground on two of the three wires if output voltage is low. Follow every step and it will answer. If you don't have a meter you can buy one for $10-$15 to do the job.
Http://my.is/forums/f221/diy-charging-system-full-diagnostic-alternator-battery-426000/
Post your findings.
As far as the the gear, i would probably replace it soon but that's just me. 2 part epoxy like JB may hold up for awhile i don't trust it really.
Discussion Starter #44
hey jason i did replace the gear with a new one. the jb weld was for the alternator stud. and i will be doing this check tomorrow. and you have been a great help.
Super Moderator
No problem. That's good to hear, great job! Make sure that harness is securely pushed in and connections are good. Even your cluster voltage meter should read around 14 and drop no less than one volt.
You don't nessesarily have to do all the alternator tests if it was fine before. Whatever you do, don't disconnect the battery while running.
--DIODE LEAKAGE: the diodes in the alternator prevent current from flowing backwards and only allow it to flow in one direction, thus creating DC current. diode leakage can kill your battery over time very quickly as it puts an additional draw on the battery when the car is off. to test using a meter: set the meter to DC amp scale and make sure the meter leads are moved on the meter to where they read current(usually this involves moving the red meter lead to the AC/DC amp plug). with the car off, take the positive wire off of the battery(this is done to avoid a short when taking the bolted + wire off the alternator). Un-bolt the battery cable at the alternator. Connect the positive wire back on onto the battery terminal, making sure the unbolted alternator wire is clear from any ground. put the red meter lead on the bolt connection(where you took the wire off) on the alternator and connect the black meter lead on the alternator wire that you took off. the current reading on the meter should indicate a few miliamps DC, typically should be around 0.5 milliamps or .0005 amps DC. anything more than a few miliamps(3mA/.003A or more) means your diodes are not blocking properly and are draining your battery when the car is off. after your done, take the + wire off the battery and then put the + wire back on the bolted connection. then re-hook the battery up. alternator needs replaced if readings are higher then mentioned as its putting a drain on the battery.
this is where i am having my problem where you say 0.5 milliamps i am getting 12.3. so does this mean i am in need of a alternator? and is this the reason whu my battery light is on?
Super Moderator
I edited and quoted part of the tutorial so i wouldn't be quoting it all. You have a 12.3mA or 12.3A leakage to ground? Is that on a car that is fully warmed up(leakage can be more at higher temps)? That wouldn't be why the battery light is on i don't think. What are your other readings, such as running power at the battery and AC ripple?
If you didn't have a battery light before, then verify your battery terminals, bolted alternator connection, and harness are plugged in. The ECU is not seeing a charge hence the battery light.
Discussion Starter #48
all other readings are as you described in the tutorial. so i seen no other issues except this leakage. and yes this is on a fully warmed up engine. the volt meter in the the car is reading proper level and with the multimeter i am getting a 12.6 with car off and 14.2 with car running. made sure plug was connected securely and is there a certain direction that the alternator wire needs to be bolted on? and i checked the fuses and none are blown. im thinking i need to take it the alternator out and take it down to autozone and have it tested.
Super Moderator
The bolted alternator connection does point towards the rear when it's bolted because there's a support and cover for it(it lays over a support kinda), but really it doesn't matter as long as it's on there securely and has a good connection.
The leakage is a bit excessive and a free alt bench test sounds like a good idea. NAPA has the best bench testers fyi, but any place will verify it. Charging and battery voltage sounds good. This is rather strange.
Discussion Starter #51
problem is fixed. come to find out one of the wires (white w/blue stripe) had come apart where previous owner had changed the plug and covered it up with heat shrink. reconnected the wire and battery light is off.
Super Moderator
Glad to hear! I thought it might be one of those three wires which is why i originally mentioned it. Better than buying a new alt! Nice job.
41 - 53 of 53 Posts
